Hello, I have 2 RTL-SDRs that I have been using with Unitrunker on Windows 7 with no problems. I then try to replicate the setup on windows 10 and install the win usb drivers and Unitrunker just says Stopped cant open. Any one have any ideas?
I have done that. I have tried even reinstalling windows several times. It always happens to bulk in interface 0000001 doesnt matter what physical device it is. Its like something in windows is holding the device.
Look in Device Manager to see if you have a Universal Serial Bus Devices class, and an entry for your RTL2838UHDIR device. The device should appear and disappear every time it is plugged in or removed if installed correctly. In any event, something is wrong with your configuration because UT and UT2 (UT2 requires 64 bit OS) runs fine on Windows 10.
