Looking for suggestions on a crimp tool. Mainly used for mobile antenna installs a few times a year. Not sure what die set would be appropriate.
https://www.theantennafarm.com/catalog/paladin-tools-1317-5478
^^ These "full cycle" style crimp tools are pretty good. The ratcheting mechanism makes sure you do a full crimp before it releases.
Plus, you can buy different dies for them depending on what you need.
I use those at work and at home, and have several different sets with different dies.
I use them for solderless type lug terminals for doing 12 volt wiring. They do an excellent job.
I have a few different ones I use for coaxial connectors, and they work well.
A couple of things to consider, though...
Different style connectors will require different sorts of crimps. Make sure the crimp die you have is the correct one for the connectors you purchase. Manufacturer specs will tell you what size cavity to use for proper crimping.
Don't forget strippers. Different connectors will have different strip measurements. However, a good sharp exacto knife will work if you are really careful.
The crimpers are only as good as the connectors, make sure you purchase good connectors proper for the cable you are using.
The other set you mentioned will work, but I prefer the ones above.
I have a set like this at home:
https://www.amazon.com/Eclipse-Tool...per+tool+set&qid=1558938680&s=gateway&sr=8-93
If you shop around, you can find the same kit with a different brand name on it quite a bit cheaper. For occasional use, it's been pretty good.
I'd also suggest...
Some connectors require soldering the center pin, so make sure you have a small soldering iron with some fine diameter solder. Sometimes you can get a bit too much solder on it, so a small fine file can be helpful.
The exacto knife I mentioned able is handy for getting the coax strip correct. The included tool doesn't always do a perfect job.
Heat shrink tubing over the crimp is a real good idea, plus it makes it look professional. I'd recommend the marine grade heat shrink tubing that has the hot melt adhesive on the inside. This makes for a really good strain relief. I add that to all my coax connectors. Most larger professional connectors include it with the kit. A small heat gun makes shrinking it easy. You can pick up heat guns used for paint stripping at most hardware stores for $30 or less.
