Assuming that you meant the entire 39 MHz. band (39.02 thru 39.98) there are some here in Illinois that use it for auxiliary or car to car use.
For example, Yorkville IL PD uses 39.40 and I wouldn't be surprised in some other 39 MHz. band channels are still used by some other Kendall County towns in that area.
Illinois used to have 39.50 as a statewide Sheriff's channel but for the most part it is all gone, just a couple towns using it for chit-chat. 39.66 was often used by mobiles to 39.50. 39.46 was a Point to Point channel for years but that is gone as well.
I think also that this band is still active in California by CHP, they moved some ops there after LA County moved off.
