396 and 996 rebanding question
jjrii
Hello,
I am a photojournalist and use the 396 and 996 daily for my work. I understand rebanding will happen this year (I am in Delaware). My question is does anyone know when the rebanding firmware fix will be available? I have a bad feeling I will be in the dark while waiting for the fix....
Thanks for your help.
John
rdale
Lansing, MI
Unless you're monitoring one of the systems affected by it - you don't need a fix.
If you are monitoring a system that is impacted, I can't imagine the delay will be long.
Viper43
John,
If you have a Motorola Type I or II system it will affect you, otherwise it won't. Theres a lot of threads here on rebanding, checkem out.
jjrii
Yes, Motorola type II and Motorola type II Smartzone :(
Thanks for the replies..
John
