396xt AWIN system programming
oem3
Arkansas
I'm trying to get a 396xt working with the Arkansas AWIN system for someone. I have imported the system via RR, the control channels are in there as well as the talk groups wanted. IF I change it from ID scan to ID search, it gets everything. I only want to pickup the selected talk groups that I've imported. When it is set to "ID scan" I get nothing on this system. I'm using the ProScan software.
Any help, thanks.
My scanner is the radio shack Pro-106 works fine for this. I'm not as familiar with Uniden programming.
wtp
Port Charlotte FL
search vs scan
go to the system and change it from id search to id scan
search show you everybody that is on the system
scan will only let the ones you want (programmed in)
i am a numbers guy and just leave the talk groups as numbers also i have locked out the ones i have confirmed and don't want to hear
that way if a new user pops up i get them
a friend in the next county got to hear a new swat channel that way.
if you need step by step just ask.
