396xt copy system
Bullmax
London, ON
When I copy a P25 system it does not show the P beside the name while scanning. Is this ok?
Fire 2 was copied from fire 1.
davidmc36
South East Ontario
I was just playing around trying that and it appears the "P" is simply part of the system name in the first one. When you look at the sites in each system they are identified as P25 in both.
I removed the "P" from the name of the first system.
