396xt + FREESCAN + GPS
HKChad
Is there a way in FREESCAN to check all the "use GPS with this site" boxes? Going through 100's of systems to check that box seems like a bit of a hassle? Is there a reason this isn't on by default when coords are available?
Thanks,
Chad
HKChad
ahh missed that one, guess I'll go re-import everything.
Thanks!
Chad
HKChad
Ok so say I'm planning a trip through several states, whats the best way to load all the systems? Just jot down all the counties and import them one by one in FreeSCAN?
thanks,
Chad
ehepner
Central, IL
thanks,
Chad
That's the only way I know how to do it with the 396 series. When I'm doing that I have the database open so I can make sure I'm importing what I want. It can get a little time consuming if you are going to be in a bunch of different counties.
Sent from my SAMSUNG-SGH-I897 using Tapatalk
