396XT priority/quick site issues
TDD326
#1
Gday!
I have just got my 396XT and im pretty impressed!
Though i can not for the life of me figure out how to set priority channels and sites.
I HAVE read the manual as well as the "easy manual", still keep getting the error no priority channels.
If some one has the time to chat about this please msg me via msn java.joe.pm@hotmail.com
Thanks again for your time!
Birmingham, Al
#2
396XT Issues
Check the display. If there is no "PRI" in the upper portion of the display (in the center of the display) then the Priority is not active. If there is a "PRI" present, but blinking, the scanner will not acknowledge the presence of Priority channels. Press and hold the "Function" button and the press the " . (period or decimal point) until the display shows the "PRI" and it is not blinking.
TDD326
#3
Cheers,
Thats what i was doing then i get the error that there are no PRI channels even after checking the boxes for them in the set up.
What else am i doing wrong?
ILL
#4
If your trying to set up priority channels in a trunking "SYSTEM" by hand you need to go to the "SYSTEM" in question, go into the "MENU" options and turn "ON" "Pri", then go and turn "ON" "Pri" on any TG's and it will work....
KE4ZNR
KE4ZNR@radioreference.com
Ron has it correct. :)
From a long ago post of mine found in a forum search:
The info below describes how to understand the differences between Conventional Priority
and Trunked Priority ID Scanning. If you are seeing the "Priority Scan, No Channel" message that
has to deal with conventional priority ONLY and not trunked priority ID scan. It means that you are trying to activate conventional priority on a system that has no conventional frequencies assigned as priority. It has nothing to do with Trunked Priority ID Scanning.
If you are seeing the "Priority Scan no Channel" message that means that you have tried to use the Conventional Priority Feature instead of the Trunked Priority ID Scan Feature. It is easy to get the 2 confused but if you do the following Priority ID will be turned on:
1)Navigate to the system
2) Select "Edit Sys Option"
3) Select "Priority ID Scan"
4) Select "On".
5) Navigate to Talkgroup you want set as Priority.
6) Select "Set Priority" to "On".
This should get you squared away.
Happy Monitoring
Marshall KE4ZNR
Ouachita Parish LA
#6
Sorry to dredge up an old thread, but I am still getting the ""Priority Scan no Channel" message even though i have enabled the priority in two different places (system as well as TG) using both Freescan as well as the KB
HELP!!
Bill
KE4ZNR
Please reread my post from above..it describes the exact message your are getting and how to fix it:
http://forums.radioreference.com/1640380-post5.html
4) Select "On".
Happy Monitoring
Marshall KE4ZNR
HELP!!
Bill
Ronaldski
MI DB Admin
Bay City MI
#11
The PRI button * ONLY * works if you have any analog (conventional as its referred to) set as a priority.
- Wishes that would get fixed in a firmware update so..... anyways,
To enable the priority function to work on a trunked system you must set it within the settings of each trunked system you have as shown in the above instructions,
If you don't have any analog - conventional frequencies set for priority, you will get that area you mention. If you have no desire to set any analog frequencies for priority, that PRI button is useless for you.
