W8GFF
I'm unable to make the startup keys bring up the proper system on my 396xt. Trying to get a conventional system with aircraft frequencies work and NOT scan the trunking systems. I follow the procedure of holding down the desired startup key with the power button but I keep getting the trunking system.
I'm a total newbie with the 396xt. I purchased it because the Navy Blue Angels use it for putting radio transmissions over the sound system at air shows. Its sensitivity on military UHF frequencies is far better than the Radio Shack Pro96.
Anyway, I purchased the 396xt and have used Freescan and ARC-XT software to program the unit. I programmed aviation frequencies into the unit using Freescan but had trouble finding compatible files for police/fire/public service. I was able to get downloads for Hamilton County, Ohio (Cincinnati) frequencies from Radio Reference and successfully used ARC-XT to get them on the 396. The conventional systems - aviation frequencies - have programmed over from the radio to ARC-XT without difficulty.
Any help would be appreciated very much!
Rob
Rob
