As I was waiting on hold for support help from Uniden I looked up some old posts on RR and conformed what I already thought. I have roughly 20 systems and assign one startup key to about half of them (ones I listen to mostly) and another key to the other systems. Problem is if I use one startup key the others are lcoked out and can't use quick keys to unlock them. Im just looking for ideas on how to manage 20 or so systems without manually shutting off ones I don't want to listen to each time I turn the radio on. Would be nice to use a startup key for the systems I want but if I get the urge to listen to other systems not assigned to that start up key use a qk to toggle those systems on.
I never got through to Uniden after being put on hold for 45 minutes. Just seems like Uniden made things pretty complicated using the startup keys and decreased their usefulness.
Quick side note I just got a gre super amplifer and dramtically imrpoves the signals I get. I was suprised after some of the bad reviews I have read. I have also used a Diamond srh77ca and a radio shack 800 mhz antenna. In my case I found the radio shack antenna to be the best one for all around reception.
