What happens in the following scenario? Scanner is set to Location Control OFF. Range is set in scanner to 0. My location is just outside the 25 miles.
Geocoded data in database shows system range set to 25 miles. Often the geocoded data does not match the license shown at the FCC nor does it indicate the actual distance from the transmitter that the signal could be received. So, I believe the system would be scanned with Location Control Off assuming the favorite list was selected. However, because the range in the geocoded database is only 25 miles what happens if I'm monitoring just outside the 25 mile radius with scanner range set to 0. Obviously the signal strength is there to hear the transmission.
See attachment. It's scenario B that I'm interested in when Location Control is off. Do I hear it or not? My initial reaction is that it gets scanned because Location Control is OFF but you get no audio because the Geocoded data is at 25 miles.
