Looking for the Talk Group Numbers for Allen Co Fire ops 11-15 these are open channels and not encrypted....
There is a scanner feed for Allen Co. you can hear OPS 11 Was listening today to the large fire in New Haven..
These are the respective TGIDs:
Ops 11- 2011 (Listed as Ops 1)
Ops 12- 2013 (Listed as Ops 2)
Ops 13- 2015 (Listed as Ops 3)
For the most part, the county fire departments pretty much use Ops 11 all the time when multiple departments respond to an event. These are on the Allen Co. P25 800 system.
That’s interesting find. Allen County never links a dispatch channel to a ops channel so I’m not sure what you’re seeing however I was listening to the run in question on my APX and the dispatch channels weren’t patched nor was the ops channel so I’m not sure what’s going on. The only time channels are patched are FWPD channels with ACPD prior to moving to a tac channel but for fire the dispatch channels are never patched together nor to a ops channel as this would create massive issue with station alerting. I will say the talk groups were shuffled around quite a bit a few years ago. Due to the mixed encryption on the system a large scale edit will be most likely impossible.
Listened to a multi agency call and no patching was done at all. I wonder if the talk groups have changed that the current list is outdated. The only ‘patch’ I know of is between vhf county fire and 800 county fire. Ops-11 did not have any comms with the dispatch talk group.
Ok they were only simulcasting on vhf/800 county fire dispatch.
