What Antenna can i use for new F150 aluminum body ?
What about a galvanic action between the typical "brass" mount vs. the aluminum sheet metal over time? Seems you'd likely lose the ground connection.
Galvanic action occurs when two electrochemically dissimilar metals are in contact and a conductive path occurs for electrons and ions to move from one metal to the other. One metal corrodes as its ions are deposited onto the other metal.
The headliner is no problem. Take the 3rd brake light out, you can see exactly where you can drill. The headliner is 1 piece formed board. You can route the cable around the back of the cab and around the trim with no issues at all. I installed a NMO 800 antenna in my 2018 F150 in less than 30 minutes start to finish with cable routed to dash. I also mounted and NMO on the edge of the left fender opposite with the FM antenna is and am using a VHF 1/4 wave. No issues with SWR from the A post and no issues running cables.I've wanted to do this, but fear how difficult it is to lower the headliner. If it wasn't for the headliner being hard to get inside of, I'd have no issue drilling the holes.
You really don't need to drop the headliner. In addition to pulling the 3rd brake light, you can usually drop the center dome light. The pull the gasket off the door frame along the head liner and part way down the B post. Now you can easily slide a fish tape up between the headliner and the roof and route your antenna coax as needed.I've wanted to do this, but fear how difficult it is to lower the headliner. If it wasn't for the headliner being hard to get inside of, I'd have no issue drilling the holes.
2009-2014 F-150 is NOT an aluminum body (source: the truck outside that had a magmount all the way to AZ and back...not my truck so no NMO).
