I ran into a strange reception problem with my Uniden. It may not be specific to the SDS100, but I don't have another radio to test with unless I can get my Yaesu fixed. Here's the situation. I mainly use my SDS 100 in my car. I have the radio's USB charging port plugged in to a Comkia power adapter. The adapter plugs into the car's cigarette lighter socket. The Comkia has three open power ports -- 12 VDC, and two USB 2.0 ports, one putting out 2.1 amps. I plug the SDS 100 into this port, using the Uniden factory USB cable. It works fine, and keeps the SDS 100 charged up. I have to use the Comkia because my car is an older model and doesn't have any built-in USB ports. The SDS 100 is also plugged in to an external roof-mount antenna. The scanner is set to scan various public service channels in the 400 - 700 Mhz range, both analog and P25 digital. It works quite well.
Today I decided to set the scanner favorite to CHP (42 Mhz range). The scanner went around to each programmed frequency but failed to receive any signal on any of them. I tried switching antennas. Nothing. Next, I unplugged the SDS from the Comkia. Bingo. Normal reception and lots of activity on all frequencies from Marin all the way down to San Jose. I plugged the SDS back into the Comkia, but with ACC off (no power to the Comkia). Continued to receive transmissions. Turned the ACC ignition key on so power flowed to the Comkia but the engine was still off. Bamb. Stop receiving any radio transmissions.
It seems like the Comkia is acting like an RF shield or something on the lower frequencies. I would replace it with another brand if I was sure the same thing wouldn't happen with another power unit too. Any RF/electrical insights are appreciated. This seems like an obscure problem but maybe it's not.
