I have his bcd536hp but can get awin Benton county fire departments and Benton county sheriff on there for him I have a home patrol 2 and miraculously got it on mine somehow can someone help us/him he would probably be willing to pay this scanner I think is pretty advanced I know is project 25 phase 2 I just haven’t used trunking radios much since asp started that many years ago thanks in advance
If you have your HP-2 up & receiving, using a Favorites list, you can export that list to an *.hpe file. Then, if you'll install Sentinel for the X36HP scanners (same program used for the SDS100), you can import that Favorites list export (the *.hpe file)into the x36HP version of Sentinel, and then load it into his scanner. The base programming for the HP-2 will import into the x36HP Sentinel. The main differences are that on the 536HP (and 436HP) scanners, you can set alert colors to come on when a specific channel or talkgroup is active, and you can set Priorities and Quick Keys if desired. But the base system programming is the same.
If you are just using location & zip code, not a Favorites list, then install Sentinel for his scanner. Update the database, then write the database, along with range & location selections, & he can start listening. Be sure that in the x36HP Sentinel that you enable the Service types in the profile.
