DVE
Hi all,
I bought this thing on eBay - Motorola Talkabout T900:
And I became curious if is it possible to test it
According to the seller, it was working in the US Skytel network.
After a short search in Google, I got this:
- The pager is using the ReFLEX 2.6 protocol and is using two different frequencies, 896-909MHz to transmit and 929-942MHz to receive, but the exact frequencies are not known.
- ReFLEX protocol should be compatible with a standard FLEX, at least for downlink, so in theory, it should be possible at least to send a message to the pager. But the capcode and frequency are unknown. Can 021757751 be a capcode? It looks too long, but maybe FLEX capcodes can be longer than POCSAG capcodes?
- Uplink can be more tricky. I was not able to find a full ReFLEX protocol description, but what I see, is that FLEX is a protocol that relies on strict time synchronization, it looks the pager should get downlink frames first and be in sync. Using the menu it is possible to create a message and try to send it, but I getting the error "transmit failed", and according to my SDR, no signal is actually transmitting at all - the pager is waiting for something.
Questions:
- Is two-way paging active somewhere? If yes, it would be nice to have IQ recordings (but I think I'm a bit late
- Maybe somebody knows/remembers the US Skytel paging frequencies
- Any ideas about capcodes in FLEX/ReFLEX protocol? I was able to find this Wayback Machine but it's only a whitepaper for managers and sales guys, mostly no technical details inside.
- Open-source software. I was not able to find any ReFLEX encoders, but FLEX encoders are available for GNU Radio, so maybe it is possible to send a message to the pager, and after some incoming frames pager can be synced and even it will try to transmit as well, but the chance looks low.
Any other advice is appreciated.
Questions:
