To anyone looking to acquire commercial radio programming software:
You can't adjust the priority check interval. It's standard at 1 second. If you use dual watch instead of priority scan, you can adjust the dual watch priority timer under Common-Scanning.
Also, if you have home channel scan set, it during the priority check, it will scan your priority channel and your home channel, lengthening the scan pause.
You'll need a VMDE-200 option board to decode MDC-1200. They only work on a certain firmware level and above (I forgot the level, sorry) And they will NOT work on the "P" P25 Edition 820/920 series. As for the light, there may be an option to shut it off, but if i remember correctly you can only change the color.
