Baofeng CHIRP import problem
KF0CQP
<unknown>:1:653: not well-formed (invalid token)
I just signed up for premium at radioreference.com and cannot get CHIRP to query. I received the above error. Can anyone help me.
Complete newbie here. Be gentle. :)
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Chirp doesn't use the RR import function - it's their own design. You should post this on the Chirp support forum on qth.net
Mike
KF0CQP
Thank you but these links aren't very intuitive and I wasn't able to find any place to post my question. And I already updated CHIRP yesterday from the other link you provided.
Prior to my post, I also did a lengthy Google search with no results.
Still no solution.
KK4JUG
GA
What radio are you trying to update?
n0xvz
Member (barely)
San Angelo, TX
What operating system are you using? What radio are you trying to update? Did you download an image of your radio before trying to import from RR?
The error you posted appears to be a generic error (at least from what my novice self reads). If you sign up for the mailing list, it will let you send your question to everyone subscribed. I'm confident someone there could better help you with your issue.
KF0CQP
Baofeng uv 82
Windows 8.1
I've tried manual entry and csv and am having no luck that way either. I dont understand/remember what all the columns are for. This software is the pits.
I gave up. I queried from zipcode and then made dually entered on my radio the other 65 frequencies.
I'm just feeling a bit deflated. Alot of trouble for no activity on my radio except the weather. Yeehaw. What. fun new hobby. šŸ˜‘
KK4JUG
GA
Your problems are probably not with Chirp or Windows. Rather, it's the radio.
KF0CQP
Helpful. Thanks.
How can the radio be a problem if I haven't even gotten to the point of loading channels and turning it on?
KK4JUG
GA
A little research on this site will show you that it's not a well thought of radio. While there are some admirers, the initials CCR* are generally used to describe the Beofeng and similar radios.
*Cheap Chinese Radio
nd5y
Wichita Falls, TX
KF0CQP
I can read and I did read and it was about as much help as the answers I'm getting here. But thanks for playing.
n0xvz
Member (barely)
San Angelo, TX
I'd love to help you, but I don't know the root cause of your problem. I could only help you troubleshoot so far.
I'm going to suggest again that you sign up for the mailing list and ask your question there. I'm confident someone there could better help you with your issue.
KF0CQP
I might but mailing lists don't usually answer questions. They just spam your inbox. And you've been very courteous. Thank you. But I just input all my channels manually. And since I only paid for membership here so that my import would work, I'll probably be asking for a refund.
alcahuete
Southern California
CHIRP and RadioReference are not affiliated. If CHIRP isn't working, it's a problem with CHIRP, or user error. The RR Database works just fine.
