It's the time that the scanner uses to determine whether a signal is Digital or Analog.how adjusting that helps receiving a system up or down?
It does nothing for digital or decoding performance. It's just an audio mute function that makes the audio mute for the time set from the point where the squelch detects a carrier. It will not override the Hold time set to a system.I noticed that the system defaults to 400ms and I was wondering how adjusting that helps receiving a system up or down?
I have tried Search and Close Call both and seem to get better results from the search option.Good luck with it on Close Call.
Any time it gets a hit, and the freq is P25, NXDN or DMR, it just sits there making noise, and does not decode. Pretty pathetic.
This is on Close Call only, actual searching will yield results.
Great info thanksSearch have full sensitivity but CloseCall are much worse and the signal must be both close and strong and pretty much the only signal to let it trigger a hit. In previous scanners it was a specific chip that handled closecall and needed a lot of signal but I do not know if it works any different in SDS scanners, probably not.
To detect a transmission using CloseCall takes something like 1 or 2 seconds but using search could take minutes if you search all frequency bands, and by then the signal could be gone and not found.
/Ubbe
I thought it was just me thank you lolOn Close Call, I can be right by a Mototrbo tower / Site, full signal, RSSI -60 DB, and it still just sits there "motorboating" never decodes the digital.
The instruction manual says that CloseCall are used to find frequencies and the function settings lack any means of setting decode modes like it does in search. There's probably a reason to why it isn't supposed to decode digital formats, even if it's hard to understand from a technical standpoint. When you find a signal you probably would want to know what it is and not just let you listen to meaningless digital noise.On Close Call, I can be right by a Mototrbo tower / Site, full signal, RSSI -60 DB, and it still just sits there "motorboating" never decodes the digital.
Wasn't there some sort of issue with close call because DMR is TDMA
/Ubbe
There is no luck involved. Close Call works.
