Fairfield, Ill
Phrostbyte74
Effingham, Ill
Hi - I live in Fairfield, Ill and was wondering if someone in the area could recommend a scanner that can pick up local PD? I've been looking at a Homepatrol-2 but I donno if it'll pick up anything in Fairfield.. Thank in advance! Been out of scanning for a couple years..
hiegtx
Dallas, TX
Hopefully, someone closer to your area can provide more specific recommendations for you.
Looking at your county, Wayne, in the database:
Looking at comments on the county's page, I see that your Sheriff's Office is using DMR, which the HP-2 cannot receive. Their dispatch channel shows to be fully encrypted, which no scanner will ever be able to hear. However, comments, as well as the licensing as indicated, suggest that possibly other S.O. channels may be using DMR, or might be converted to that. If there additional DMR channels in use, so far they are not listed in the database.
For your specific city, Fairfield, the page shows your P.D. is using NXDN, another digital format, for dispatch. It is not flagged as encrypted, but maybe someone near you can confirm that. The HP-2 cannot receive NXDN either.
While there is a site for the statewide system, STARCOM21, in your county, at present the county database page does not indicate that any of your local agencies are using it.
For Fairfield, you may want to consider a scanner capable of NXDN. In the Whistler models, that would be the TRX-1 (handheld), or TRX-2 (a base/mobile model). Those scanners can receive both NXDN as well as DMR. As already noted, the S.O. in your county is using encrypted DMR, which nothing can receive. But if they have other DMR channels in use, that are not encrypted, then you may be able to monitor. These two would also let you monitor your city's PD, on NXDN, as long as they stay non-encrypted.
In the Uniden line of scanners, you would need a scanner that can utilize the paid upgrade for NXDN (if you want to be able to monitor Fairfield). Those models include (handheld) the 325P2, 436HP, & SDS100. Base/mobile models include the 996P2, 536HP, or SDS200. Any of these scanners can also receive the paid DMR upgrade, if you find other, unencrypted, channels are in use. The SDS series scanners would be overkill for your area, without any simulcast to deal with, unless you intend to travel to or through other areas where simulcast is used. While the two P2 series scanners would work for your area, presuming the database page is accurate, the 436HP & 536HP, being database scanners, would be easy to set up using the Sentinel software Uniden supplies (free) for them. While you can manually program any of these scanners via the keypad, including the 325P2 and 996P2, software makes it much easier and quicker, and also far easier to catch & correct any errors. The FreeSCAN software can program your basic channels in the P2 scanners, but cannot handle NXDN at all, nor does it correctly support DMR programming. You would be better off with ProScan or ARCXT. ProScan can also handle the x36HP scanners, as well as the SDS models. In the ARC software, you would need ARC536 of using the 436HP/536HP, or an SDS scanner.
VASCAR2
So Illinois
From what I was told Fairfield PD is on NXDN encrypted but still has analog capability. Wayne County Sheriff‘s department has supposedly migrated to DMR system on VHF high band and is encrypted. There are several Starcom 21 sites near Wayne County. Depending on your actual location and antenna will determine how many sites you can receive. The Fairfield SC 21 site is located on CR 1000 N just east of CR 2050 E north east of Fairfield.
There is a SC 21 site near Bluford just north of Route 15 on Jefferson Co Road 2125 E/Seagull Lane. There is a SC 21 site near Thompsonville, Sumner and Flora.
The SC 21 Fairfield site usually carries radio traffic for Illinois State Police District 19, 12 & 13. Ameren/CIPS, Illinois DOT are also on SC 21 but to my knowledge no Wayne County Agencies utilize SC 21.
VASCAR2
So Illinois
A Friend of mine has a BCD536HP and an SDS200. Another Friend has a BCD996P2 and I really like the BCD996P2. I had my BCD996XT next to the BCD536HP and they are very comparable in reception. I like the display on the BCD996P2 better than the BCD536HP.
I noticed Amazon had the BCD996P2 on sale for $350 and for that price I’d jump on the BCD996P2. I think the BCD536HP are close to $500 and I don’t think it is worth the higher price for use in Wayne County or Southern Illinois.
The BCD536HP might have more memory for storing more systems and talk groups which might be an asset if you lived in a very large metro area. In a Rural area with no simulcast trunked systems the BCD996P2 is a very good scanner.
