R6 IC R6 shuts off
thepaulmc
My R6 will just shut off for no reason. The batteries are fully charged and I am running it on the Icom drop in charger. ( yes, it is plugged in ). Any suggestions?
eorange
♦RF Enabled Member♦
Cleveland, OH
Does it shut off when you remove it from the charger and running on batteries only?
thepaulmc
I am using duracell NiMH 2200.. It still shuts off when on batteries at times also, not just while plugged in.
k5xs
This to me points to a power issue. I’d make sure the battery connectors are mechanically solid and very clean.
FKimble
Newnan, GA
Does it shut off on battery only, not in the charger? And will it power back up after it shuts off? Does it have to sit awhile before powering back up? Possibly a component is overheating when remaing in the charger for long periods of timw?
Frank
eorange
♦RF Enabled Member♦
Cleveland, OH
Any chance you programmed it with an early version of Butel software? I seem to remember that if you programmed a bank for scanning with duplicate channel index numbers, or maybe non-contiguous numbers...it would cause instability in the radio.
