Is there any software that can turn SDRs into "Police Scanners"
Spflowers92470
South Bend IN
Is there any software out there that can turn an SDR, or a couple of them into a "scanner", I know about SDR trunk, but I am talking about software where you can put in a list of frequencies that are not trunked, and have it scan threw them. Would be nice if it could handle DMR
Thanks In Advance for any help
Shane
noamlivne
DSDPLUS Fastlane with regular rtl-sdr dongles (using fmp24) can scan non-trunked analog and digital (list of) frequencies. You can record the digital ones and play them "live" and archived via rdioScanner.
ka3aaa
middletown, pa.
if you want a true police scanner just buy one rather than trying to make an sdr into something it isn't and wasn't designed to be. its a software defined radio that requires a computer to make work and happens to scan verses a true scanner that can sit on a shelf with nothing more than a power cord and an antenna attached to it.
dlwtrunked
I disagree and agree with noamlivne.
I have a SDS200. But I prefer using an AirSpy R2 with SDSPlus Fastlane. Works at least as well an have other advantages (and is far less in cost if you alread have a PC_.
boatbod
Talbot Co, MD
Shane
The challenge is that most "police" channels these days are actually just talkgroups on trunked systems, so you need to monitor the trunking rather than just skipping between a bunch of conventional frequencies. First identify the agencies you want to monitor, then investigate whether they are encrypted or not, after that you can figure out what frequencies and/or trunked systems are involved, and finally some appropriate hardware/software to perform the task.
SkinnyFirefighterMS
Mississippi Delta
Shane
You can get DSDPlus Fastline, it cost $10. You can listening to P25 Phase 1 and 2 (Conventional and Trunking), NXDN, Analog and DMR. You can scan through frequencies
dave3825
Suffolk County NY
For conventional freqs, the Sdr# with plug in route will work. There is even a simple Apco P25 plug in for Sdr#. Sdrtrunk, depending on some variables could work.
I use DSDPlus Fastlane with a scanlist for conventional freqs. In the scanlist, I listen to analog (am / fm), Dmr and P25 and it does very well and use only one dongle.
How many freqs are you looking to scan?
dave3825
Suffolk County NY
Spflowers92470
South Bend IN
Thanks, but I cant afford 700 bucks for a SDS 200, I live in a simulcast area, and SDR Trunk works great for that. I am basically trying to find something to scan DMR chs on the cheap. Believe me, if I had the extra $700 (actually $800) the SDS 200 and the DMR upgrade would already be mine.
Spflowers92470
South Bend IN
Well the local casino, they use DMR radio's, the city snow plows, they also use DMR, maybe 25 to 30 freqs
Spflowers92470
South Bend IN
I have looked at DSD plus, that looked complicated, that might be above my pc skill level lol
dave3825
Suffolk County NY
In my opinion, an sdr with the right software has more advantages over a true police scanner. Scanner can only monitor 1 channel / talk group at a time. Sdr with the right software can monitor multiple systems and talk groups simultaneously. And with trunking recorder handling playback that to can be customized to play what ever you want to listen to. I have many scanners and an sds200 but it's so nice to have sdr running and recording everything 24/7. For people on a budget, it's a great alternative with the added features.
It's really not difficult after the initial learning curve. Basically just populating a text file with the freqs of interest and let it scan. When one of the freqs becomes active, it will either pass analog audio to your speakers or if digital, it will decode that and pass that thru the speakers.
Spflowers92470
South Bend IN
I have the Police covered, I have a whistler 1065, but have simulcast issues with it, and I use SDR trunk. I am trying to listen to the local casino, and local snow plows, they use DMR. But thanks for the info
Spflowers92470
South Bend IN
Well it has been awhile since I looked at it, will have to check youtube out and see if they have any how to videos, thanks for the info
JamesWest
you will love the SDR# waterfall display that shows all the RF activity around you.
SDR dongles are super cheap or go with Airspy Mini on sale now.
SDR# is not that hard to setup and get going and learn for basics like scanning and storing frequencies.
Vista
West Chester, PA
I've been trying to figure out the same thing, I would like to listen to multiple closely grouped nbfm frequencies, but having trouble with the json setup for multi_rx in OP25. It works well using two dongles, on two nbfm channels, but would like to be able to monitor or scan multiple frequencies, similar to how you can list multiple control channels for P25.
boatbod
Talbot Co, MD
Sorry, multi_rx doesn't scan between defined channels.
If the frequencies are close you can define multiple channels to use a single dongle, but it demodulates each defined channel simultaneously.
