XTL/XTS5000 XTS5000 PTT fix
jeanlikethis
Hello, my XTS5000 (purchased from ebay) has an very much over used PTT button. There is no much feeling of pushing it, just press hard and the radio MIGHT be in TX mode.
Other than that, the radio is in good condition. Can I just fix the PTT button part of the radio?
Thanks and have a nice day.
mbnv992
AZ
You’d have to get a new housing for it. The PTT button itself is a non-serviceable item.
jeanlikethis
Thanks. I saw some housings for sale on ebay. Are those housings OEM parts or, some unknown 3rd party products? All the best
jeanlikethis
Thanks, your solution makes a lot of sense. The original housing is a high quality one and I do want to keep my XTS5000 in the original professional way.
Just want to make sure 700/800MHz housing (PTT, turrets and display, side port,etc) shall be compatible to my UHF one. Thanks a lot.
jeanlikethis
Thanks a lot. It is harder to find a original housed XTS5000 now, especially on UHFL band. I am happy I moved fast when there was still a chance.
mbnv992
AZ
Yep all the XTS5000 housings are the same no matter what bandspilt the radio is in. The 800MHZ ones are going for dirt cheap so just look on eBay find the best looking model 3 ( or whatever model housing you currently have ) and get that one - switch out the housing and bingo - all set !
chrismol1
P25 TruCking!
It was a few years ago and the button broke on my otherwise mint condit 5000 so I put on a cheap ebay aftermarket side button & paddle repair kit but it requires the existing housing sidepiece to be hacked up carefully and the new piece super glued in. I started with tearing it apart from the middle button up to not have to use tools on the side housing. The piece was not flush so I ended up with a dremel to bring it down a bit. not ideal but at the end of the day it was working. If there's one of those new aftermarket ebay housing or original with the piece already in, I'd get that.
Giddyuptd
Here and there
When it comes to the 3000/5000 third party housings you're better off getting them requesting the side ptt not installed. They use to get them finished or some unfinished then assembled In CA. Not sure if they still do but worth a shot.
I only say this as when they put them together the glue will slide under the areas where the ptt is or buttons on side panel as they slap them together moving onto next by hand.
As for buying a used a 700mhz this is also a option and never hurts. At most you'll have a radio where you can rx the 700-800 interops using the housing for what you need.
You may check wiscomm, sandy communications or sunny communications. They may be able to get you a oem new or used decent condition oem.
There was a couple used model 2 oem or one was new other used on ebay. About 99ish bucks. But unless you wanna remove the guts you're better off doing as said getting used 700mhz radio as they are cheaper than that or same.
By the sounds of it though you have a radio that has a third party housing that was outfitted at one point on radio before you owned it. Common classic sign with the third party 3/5000 housings.
jeanlikethis
Thanks for all the messages and information. I am working on it. If can't find a original housing, I would prefer keeping what I have now. XTS5000 is a great radio, I want to keep it the original professional way.
All the best.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
I have a single brand new yellow Model 1 (no display or keypad) XTS5000 housing that I was going to list on ebay. PM me if you're interested.
If you are patient and careful, the electronics can all be extracted from an XTS5000 housing and swapped over to another one.
jeanlikethis
I currently fixed the button myself. I removed the button carefully and cleaned the inside. I put another bushing to the under of the button to make sure the pushing travel is not too long.
After I put the button back, it feels much better now.
Currently, I am searching for an OEM housing for my item. It needs a new housing ultimately.
