451 FTS & 455 FTS Question
Schertz, TX
#1
I am looking for call signs for the 451 FTS a& 455 FTS out of NAS Pensacola, FL. Planes from the 451 FTS a& 455 FTS fly in to Randolph AFB. Does anyone know if the GATOR call sign is still being used?
Don
N1GAW
Check this list, it is updated regularly and pretty accurate. For Randolph I noticed Gator (T-43), Hangover (12th FTW), Kiowa (C-12 332nd ALS), Tonto (T-1A), Luzon (T-37), Randy (T-38), Ranger (T-43), Spur 01 (AETC Commander AC), there may be others, that was a quick look.
Military Radio Callsign List
Schertz, TX
#3
That is the same list that I use. Most of the call signs on that list are up to date. The call sign Luzon is a T-6 call sign from the 559 FTS. The 332nd ALS) is not here anymore. The T-43 has been replaced with the T-6. I am waiting to here if they are reusing some of the older call signs.
Don
