158.7825
cobra
Columbia SC
Does anyone know what EMS system this might be? I'm copying it in Columbia with a PL tone of 162.2.
evan
South Carolina
can you describe the type of comms you are hearing? Have you heard any locations mentioned? Does it sound like a repeater?
ecps92
Taxachusetts
see if you get the same traffic on 154.1300 the Repeater output for Lexington County..
as a tourist, but looking over the FCC license this is likely the repeater input
evan
South Carolina
You are right. It’s definitely the input to Lexington county fire dispatch 154.13
cobra
Columbia SC
Thank you very much for your help. I wonder why it didn't show up in the radio reference database under frequency search?
ecps92
Taxachusetts
Probably (unable to look at inputs anymore) never submitted as the input
brian
DB Administrator
South Carolina
It had not been submitted previously, as far as I know. I went ahead and added it to the db this morning after reading this thread. Even if you can't see it, it's there. I confirmed that it does show up in a SC db search now.
It's always good to remember that the RR database is based on submissions from members/hobbyists, so it is only as complete and accurate as our members make it. It is supposed to only contain information that has been confirmed by someone listening and verifying that the frequency/talkgroup/channel is actually in use. There is no automated way that information is added to the database based on another data source, like the FCC database. No one is specifically tasked or compensated for searching out information to add to the database. So please make use the of the submission button when you discover and verify information that isn't in the database at all, or needs to be corrected.
The same is true for purging old information from the database. If you discover something listed that you know is no longer used (like when an agency moves from a conventional channel to trunked radio system talkgroups, as an example), please submit that information as well.
riccom
My wife and kids said i have to many radios!
Yankton, South Dakota
158.7875 is used here in Gaffney , Cherokee county as a vhf ops, unlicensed, its used here
ecps92
Taxachusetts
riccom
I do not know, I hear Gaffney pd on it, so maybe it's for the fd and Gaffney fd mutual aid .
KG4NHF
Listening in Spartanburg and 158.7825 appears to be patched to 460.275
