452.75 RAN 40 NW AR PD/Security?
wbloss
Joplin Mo
#1
Probably another Smith Two-way license, used by a local PD or security firm
Hearing an NXDN signal RAN 40 on 452.75 with at least 20 different RIDs doing AR license plate checks, VINs, and other security type things. Has an unpleasant mechanical beep between transmissions. All transmissions seem to initiate from mobiles to the base, no real dispatching to specific incidents heard.
Somewhat odd as the TRX does not show a Talkgroup, just the Radio IDs.
Can't tell exactly where or who and only hearing when band is up.
Need a local to monitor and see if they can determine who/what!
W
wbloss
Joplin Mo
#4
