Anyone know how to get Port Chester PD to work on SDR Trunk ? I will pay $50. Thanks.
usmm01
Anyone know how to get Port Chester NY PD located in Westchester county to work on SDR Trunk ? I will pay $50.
They recently changed to the P25 Phase 2.
I used the Radio Reference auto fill in with SDR Trunk and i just get idle. Im currenly using two dongles. Im will to pay $50 via cash app or zelle. Thanks.
dave3825
Suffolk County NY
Post pics of your sdrtrunk settings for the system. If you set it up as phase 2, I believe it wont work. I set mine up as phase 1 and I receive Port Chester just fine on Zone 1 and, when I can lock on, Zone 3, I am on Long Island.
dave3825
Suffolk County NY
It looks like your trying the Zone 1 Nassau site. I am very close to Nassau so I get it fine. You want the same setup but with the freqs for the site nearest to, which would be Zone 3 Westchester. You could most likely stop the tuner, then change the Zone 1 freqs to the Zone 3 freqs shown below.
Westchester769.90625c770.18125c770.46875c770.71875c773.03125c
The name of your alias list is Port Chester pd. Is it safe to assume that Port Chester tg's are the only tg's in the alias list?
usmm01
belvdr
No longer interested in living
just says idle
What's in your alias list? For troubleshooting, you could enter a TG range, such as 1-65535, to listen to everything.
dave3825
Suffolk County NY
If its just saying idle then you are not receiving the control channel. Post new pics of your set up with the tuners tab also.
You did change to freqs to reflect Zone 3, right?
usmm01
so I should also have one dongle on zone 3? how do I do that? Thank you
dave3825
Suffolk County NY
You should bump up the Master (gain) until you see the signal rise above the noise floor. Are you trying to do 2 systems with the same dongle?
Easiest way I found to have 1 dongle per system is to set auto start on each system.
usmm01
I have two dongles because i thought I needed it to get port chester. I max out on gain at 42.
usmm01
dave3825
Suffolk County NY
Oh, I see those are E400 dongles. I have never used those. I can R820 up to 495.
That dongle most ikely maxes out at 2.56. You would need to to cover 3.12. But either way you do not seem to be getting a signal on the control channel. You should still show signal on that.
usmm01
what else could I do? my library is up to date. 1.0.9
dave3825
Suffolk County NY
I would stop the tuner and then go into the tuner tab and manually tune to the active cc of 769.90625 and watch the spectrum and see if you can get the signal better like shown below where I am using 770.90625.
What are you using for antenna?
usmm01
im using a small whip antenna on a magnetic base. The PD station is a few blocks away and im also able to listen to long island and northern westchester. Im going to try and change the control freq.
I thought the SDR would scan thru those listed?
usmm01
its strange. its like those control freqs. are not working. I get control working well on Westchester P25. but not on Metro-25/MTA MRSSbbvb.png
