How to tell if an XTL 1500 is inhibited?
danielbts11
W2DJB
Gloversville, NY
I just bought a few radios, one is an XTL1500 which I am not familiar with. The radio does not appear to power on. All it does is flash two led status leds, after it is turned on from having no power connected. The other thing- when holding the emergency button and menu button all the way to the right, it will flash the flashing screen quick and disappear. My computer will detect the radio being connected when it flashes the screen and then it disconnects.
I have no idea if the radio was inhibiting or my other theory is that it has something to do with the ignition sense being on (the accessory connector looks pretty clean like it had something connected)
danielbts11
W2DJB
Gloversville, NY
Next question - I have the ignition sense disabled, is there anyway to disable the emergency jumper, radio still won't turn on unless I have that connected. I am assuming it's a physical security thing?
dfb8085
Cumming, Ga
I got one doing the same thing. Actually it has no display either. Iy appears to me to be power cycling or boot loop with each beep because the com port goes in and out with each beep. It will not stay long enough for the CPS to establish a connection. I am using a usb cable that I rigged going into the rear plug. confirmed good on othe radios. If i could find out a way to get it out of boot loop I think I could bring it back to life. Any idea how I may proceed from anyone id greatly appreciated.
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
You need the rear 26 pin connector with the emergency jumper in place and a ignition sense wire.
On an XPR4550 is the Emergency pin needed for standard radio operation via the accessory plug? If so, does it need +12 Volts applied or what? TNX!
Bote
know-it-all
Negative. No need to have anything plugged into the ACC connector On a XPR4550/5550
To be more clear, I will be operating the radio over the PTT and TX Audio lines that appear on the rear accessory connector. But don't I need to supply +12 Volts to the ignition sense line at least? TNX.
wa8pyr
Staff member
Lead Database Admin
Ohio
I've seen that happen before. Check to make sure there's enough current getting to the radio (ie power supply is big enough, power wires are big enough, etc). If the radio isn't getting enough current to operate it'll constantly loop like that.
KC8ESL
Mentor, Ohio
The head flex cables are probably trash. Unfortunately, finding flex cables to replace them are nearly impossible.
