Baofeng UV21 Pro help needed.
N1SQB
Somewhere On Earth
Just got my Baofeng UV21Pro in the mail. Fired up ok. Receives fine. Downloaded the software from Miklor for this radio. Using a Baofeng cable, shows up on com 3 as working properly. Set the port on the software. I try reading it and I get “Failure” on the software. Any ideas?
( cross posted in an attempt to rectify my problem).
Manny
W3KBO
Harrisburg, PA
Manny
The UV21 Pro is likely a UV-21R. Look in the battery compartment. The same vendor is selling these as 21 Pro all over eBay and AliExpress. The correct CPS is named as "13 17 15R 21Pro CPS Setup v1.04 en.zip" and can be downloaded here:
https://edisk.qiye.163.com/api/biz/...4755&title=13 17 15R 21Pro CPS Setup v1.04 en
The link responds a bit slowly, but you'll get there. FWIW I have yet to see a real 21 Pro. Everyone who has purchased one of these has received a UV-21R
Oh, and the manual can be downloaded from https://edisk.qiye.163.com/api/biz/...4423fa292c49c3bc89b84&title=uv-21系列(gd)说明书5.8
N1SQB
Somewhere On Earth
https://edisk.qiye.163.com/api/biz/attachment/download?identity=60f4e41abc8e4f66a14958a31ae14755&title=13 17 15R 21Pro CPS Setup v1.04 en
Oh, and the manual can be downloaded from https://edisk.qiye.163.com/api/biz/attachment/download?identity=e87f81df16d4423fa292c49c3bc89b84&title=uv-21系列(gd)说明书5.8
Thank you very much. I actually got this at another site as well just before you posted yours. I don't know what a Pro version is like, but I like this little radio so far. Not bad for the $38 it cost me.
Manny
chrisdm123
I just got this radio also. The link above doesn't appear to be valid.
Chris
KX7D
Falcon9h
software link dead now.
N1SQB
Somewhere On Earth
What is your opinion of the UV-21? Buy it again or something else in the same price range?
It's an OK radio, nothing to get excited about. Much like all the other Baofengs except it feels solid in my hands. Menus are the same and the long squelch tail is the same as well. If I had to choose, I would go with the UV-17 Pro GPS. Not CHIRP supported yet but a formal request has been summitted by Mr.. Miklor.
Falcon9h
How is the squelch tail on the UV-17?
How are the display on the UV-21 when using outside in direct sunshine? You guys have been using this for some weeks, how are the impressions so far?
KF0OGJ
Castle Rock, CO
I have been playing with this radio (UV21Pro/UV21R) and managed to lose some of the functionality.
Unfortunately my backup firmware is corrupted too.
Does anyone have a good firmware for this radio that you are willing to share?
Also, has anyone been able to do anything with "Firmware Flash Mode?" that can be activated by holding one of the small buttons while powering on? I think that this goes deeper than what Chirp/CPS can read/write.
mm9351
Your best option would be to download the latest firmware from the Baofeng website. I used the version for UV-17 with good results.
KF0OGJ
Castle Rock, CO
I have successfully used the CPS software for both UV17 and UV21 on this radio and have also successfully used Chirp for it.
However, they don't work when the Radio is in "Flash Mode" which I assume enable reads/writes at a lower level than normal, but that is a secondary concern.
What I most need is a way to reset the firmware back to the default, either with a good .data file from the CPS or some other procedure so that I can regain the original functionality.
