BCD536HP SD Card Replace
RandyKuff
Lorain, Ohio
Unfortunatly they involve a little more work now... But thats part of the fun....
It is a learning process... Not that hard once you get the hang of it...
Ubbe
Stockholm, Sweden
It could be a good idea to do a full overwrite operation to a SD card as it then will check all memory cells if they are fully functioning. It does the same thing when used in the scanner, when the scanner saves something, even a single byte, it will always go to the next cell in the card and if the readback show some inconsistency it will mark that cell as bad and not use it again. If you leave data untouched for a very long time, maybe one of the favorite lists are never changed, then if a memory cell starts to go weak and gets harder to read then it will not be any reaction to it, just a read error. If you always do a "clear user data" to clear all data off it, or the full overwrite, before programming it will then be able to sense if a cell are bad. So maybe once a month do a full overwrite. Most SD cards can handle ten thousands of full overwrites without wearing out.
/Ubbe
gary123
Agreed with Ubbe. It has been said before and Ill say it again. Do not cheap out on the SD card get a good quality one. It costs more but having it last and be reliable is worth it.
GargoylesRus
Everything worked out Great!
Thanks for all your help, I'm sure I'll be back with some more questions.
If this thread need to be closed, make it so.
Gar.
