Here is the discussion from the announcement. Since it mentions:
"Such limited onshore use will promote flexibility in the use of marine radio equipment in a manner that furthers maritime safety by encouraging more boaters to a carry a VHF radio. Specifically, as suggested by ACR, we will permit use of portable marine VHF radios only in areas adjacent to the water, such as docks and beaches."
I took it to refer to non compulsory vessels, since compulsory vessels do not need encouragement; they are all ready required to carry VHF radios.
From REPORT AND ORDER Adopted: August 30, 2016 Released: September 1, 2016:
G. Portable Marine VHF Radios on Shore
25. Section 80.115(a)(2) of the Commission’s Rules prohibits the use on shore of a portable marine VHF radio associated with a vessel. The GMDSS Task Force proposed that the rule be amended to allow persons on shore within three miles of the water to use portable marine VHF radios to communicate with the vessel that is subject to the ship station authorization. The Commission, however, noted that limitations on the use of maritime frequencies are intended to minimize interference to maritime communications (particularly distress and safety messages), and tentatively concluded that permitting the use of portable marine VHF radio transmitters on shore would not further the public interest. We questioned the practical enforceability of a three-mile rule, and asked whether shore parties’ communications needs could be met by commercial mobile radio service (CMRS) or PRS options. The Commission also asked commenters supporting the proposal to discuss what limitations would be appropriate to minimize the impact on maritime communications.
26. The GMDSS Task Force acknowledges that CMRS options likely will be preferred in areas with reliable coverage, and asserts that this makes it unlikely that use of low-powered portable marine VHF radio radios on land will interfere with maritime communications. It also argues that permitting such use will further the public interest by encouraging more boaters to a carry a VHF radio, which has safety benefits not available from CMRS or PRS options because marine VHF channels can be used to contact the Coast Guard and other nearby vessels in a distress situation, for bridge-to-bridge communications, and to receive maritime safety information broadcasts.
27. We agree with commenters that the public interest will be served by allowing the use of portable VHF radios ashore, so long as it is limited to enhancing the usefulness of marine VHF radios without negatively affecting maritime communications. Such limited onshore use will promote flexibility in the use of marine radio equipment in a manner that furthers maritime safety by encouraging more boaters to a carry a VHF radio. Specifically, as suggested by ACR, we will permit use of portable marine VHF radios only in areas adjacent to the water, such as docks and beaches. In addition, as suggested by RTCM, and consistent with our requirements for offshore use, onshore communications using such radios must relate to the operational and business needs of the associated vessel, and must be limited to the minimum practicable transmission time. We amend Section 80.115 accordingly. We caution operators that the Commission’s Enforcement Bureau will continue to investigate complaints against operators who improperly use marine VHF radios, particularly any violation that concerns unauthorized transmissions on 156.800 MHz (VHF Channel 16).
