Motorola CPS Question
kb1ltr
I have the HT750. I have CPS R06.12.09 Will that work with Windows 10 without bricking the radio? the Software loads But i wanted to ask before i connected the radio to my computer. Thanks.
a417
You have more of a chance with the program not running on windows 10, than windows 10 being solely responsible for bricking your 20 yr old radio. Try reading the radio.
jaspence
Michigan
I use Windows XP for my older radios, and a couple even require DOS on a s_l_o_w old laptop due to processor speed.
Tech21
As someone who has programmed my HT's with windows 10, you won't have an issue.
ElroyJetson
Of course there could be exceptions but as of yet I've found no case where CPS that runs on Windows 7 doesn't work properly on Windows 10. However I'm going to qualify that by noting that I have only installed and used a limited number of CPS titles. My sample is very limited.
K2NEC
5F6
My Waris CPS opens and runs on Win 10 but my cable drivers don't agree so I can't actually read or write a radio. Like always, YMMV
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
That’s a Win10 issue. It always wants to use the latest driver. That’s a problem if you use a USB cable with a Prolific chip. The trick is to roll-back the driver. Details on how to do this are easily found with an internet search. It is not a Motorola or CPS issue.
