slicerwizard
You just press backspace to delete the -1, then press 8 and Enter.It flashes "Warning: System Type 31 is invalid <should be 1,2,4,8 or 16>"
When I go to system/edit setting/tables/system type it shows system type: -1. I can't change it to 8.
Just enter the correct bandplan values under System Menu / Edit Settings / Tables, and then apply the updated bandplan.I have the same problem with the VHF 138 range
You're looking at DOS TRUNK88 4.63; Win32-TRUNK88-488x.zip is what others are grabbing.Perhaps knowing how to read entire postings would be a useful skill, too. :roll:
The link you provide has version 4.63 available. We were discussing 4.88 (as mentioned by the OP) and the fact that the latest version we can find is 4.86.
The easy method is detailed in the New User Quick Start section of the ReadMe.txt file that nobody reads.The 800 MHz frequencies are the Default bandplan.
While there is a "Correct" way to fix your problems via the Menu, I can't remember the applicable Commands.
I recommend that you unZip a fresh copy of the TRUNK88.CTL file, and start anew.
TRUNK88.CTL can be edited with a simple Text Editor, such as Notepad. I would suggest you change the "System Type", and replace the "800 MHz Standard Bandplan" entries with the applicable 900 MHz, or 138 MHz information, before your run TRUNK88 for the first time.
The "System Type" field can be found near the top of the TRUNK88.CTL file (about 28 lines in), and the Bandplan tables are near the end.
Not the most elegant way of doing things, but it should get you going.
Just entering 900.0000 in the Bandplan Range #1 Base field is all that's required. TRUNK88 will immediately display "System default bandplan set to 900 MHz"Look for Bandplan Range #1. Whatever is entered into that field replace it with 900.000Mhz. If there is anything in step and offset clear them out too.
TRUNK88 reports all system activity, even the odd event that it doesn't understand. Motorola could add a new event/rejection/whatever tomorrow, and TRUNK88 would still report it.What is the advantage of Trunk88 over Unitrunker?
And there's the no tap option - not everyone has the resources to tap their radio, or the funds for a CCdump-capable radio (or the will to tie it up on CC Dump duty...)
Even if you had one of the Uniden XT scanners, you'd be far better off using the headphone jack of an old scanner - headphone jack audio can provide 100% accurate decoding while Uniden's CC Dump is full of garbage decodes that would drive me nuts.
