50.315 and 54.310 ?
mancow
N.E. Kansas
#1
I've noticed when the band is up 50.315 has a carrier that is very strong at times but never any audio. Also I'm getting a similar one at 54.310 but they don't seem to be linked.
Can anyone else hear them?
Cleveland, OH
#2
Actually yes. Right now I'm hearing periodic full/half carriers on 50.315, less so on 54.310. I can't tell if the band is open here or not.
popnokick
Northeast PA
#5
50.313 mHz is Amateur Radio FT8 modulation USB data. Depending on your receiver and mode it may sound like carriers w/o modulation... and be observed on 50.315.
AlphaFive
#7
50.315
I have logged that most of May here in Asheville, it was new to me. This post has helped. Oddity that it was so widespread.
mancow
N.E. Kansas
#8
Glad it helped. Yes, it has some coverage. I wonder what the power output is. As I type this it's still there when nothing else is. It's like some guy has an FT8 setup connected to a KW amp or something.
popnokick
Northeast PA
#9
It’s not coming from a single station. Multiple ham stations transmit simultaneously for 15 seconds, then receive for 15. 6 Meter propagation has been very good lately so you are receiving even more stations than normal. You can demodulate the transmissions with WSJT-X software by K1JT. And join in the communications with a ham license.
nermel
Oklahoma City, OK
#10
Sometimes I leave WSJT running on 50.313 in the background. Great indicator of the band being open. I'm seeing hams in Mexico & Canada this evening from Oklahoma.
