BCDx36HP: 536 & MotoTRBO :(
Hilliard, OH
#1
I been using ARC536PRO to program the 536 over here in the cave. I am importing from RR and everything works EXCEPT the systems that are labeled MotoTRBO. They show up on the computer, but when I save them to the 536, they do not appear? The scanlist goes right over them as if they are not there. I do not have this problem with anything else. Just MotoTRBO.
I am trying to figure what I am doing wrong? :(
garys
Eastern MA
#10
You did buy the DMR license key and update the firmware, right?
garys
Eastern MA
#12
Thinking about this a bit more, I would check the Service Types. The RR download for DMR systems does include Service Types in the Department (users) section. If those don't match what you have enabled in the scanner, you won't hear them. You can easily enable those Service Types or change them to one that is already enabled.
Hilliard, OH
#13
To answer questions, YES of course I bought and installed the update. All DMR works *except* MotoTRBO. And also YES I do have all service types enabled. I am thinking at this point that maybe ARC is somehow importing incorrectly? But I am not even sure how to check that. Has anyone else tried importing MotoTRBO?
Sent from my SM-S820L using Tapatalk
PA
#14
First thing to try is to use Sentinel and see if that lets you program the system. That will eliminate the possibility that the 3rd-party software is the problem.
Hilliard, OH
#15
Yes I was pondering that. I do not see where Sentinel allows import, but I may juat be missing that. Heaven forfend I should learn to do it myself! :)
PA
#16
You can read what is programmed in the scanner from Sentinel. That will populate Sentinel with your current favorite lists and settings. Then program the problem system in Sentinel, and write back to the scanner. You don't need to "import" from ARC.
Hilliard, OH
#17
Yes. What I was meaning was importing the MotoTRBO from Sentinel. I think I'll have to do this manually. That means learning how. But I can program conventional and EDACS, so I am sure I can figure it out. :)
