I’m an OTR driver and I use it everyday from west coast to east coast , I love it
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
Jason WX4JCW
State police, yes. County and city level police, fire, and EMS, no.
Sounds like you would be the perfect candidate to offer up some tips and tricks!
1. If the freq is listed as analog and tagged as analog search, then you will hear digital noise if it is actually digital. Submit a correction to RR to fix.
2. If the range data for a site or department is inappropriately large, the only way to edit it is to submit a correction to RR. That will fix the problem for everyone else, not just you.
You cannot edit the Full Database in Sentinel. You'll have to append to a FL and then edit as you see fit.
Keep in mind that, at the current time, the RR database doesn't support rectangular service areas. It's all circles around a set of lat/long coordinates. This is also the default within Sentinel, but you can choose set up rectangular areas to more accurately reflect agency and/or geographical boundaries.
1) I noticed I was getting several stops on 'digital noise' instead of hearing the audio - in other words, it'd stop on a channel that was DMR but it was as if I was listening to it with an analog radio, just the digital noise. Will the scanner not automatically decode the DMR audio??? Or am I hearing it because the db shows it as analog instead of DMR?
2) I had my range set to 2.0 miles but would still hear things from 2 counties away (mostly on a trunked P25 system). Is this likely because the 'range' data for the talkgroups is set larger than it should be in the db?
