Sorry I thought I added the link.
MikroTik RB2011UiAS-2HnD-IN
If I were you I would do a WIFI factory reset on your scanner.
If you are interested, I had a thought come to mind:
While at home with the scanner in your vehicle, do the following:
Menu>Wi-Fi Setup>Set Connection>Infrastructure Mode The scanner will give you a list of all the wireless routers it sees. Make a list of all you see. Then back out of this by repeatedly pressing menu until you are back to normal scanning.
Next, drive your vehicle with the scanner and dongle still running to a location at least a half mile from your home. Then repeat the Menu>Wi-Fi Setup>Set Connection>Infrastructure Mode process making a second list of observed wireless routers. Then back out using to menu button to normal scanning.
If you see a given router showing up in both lists, most likely it is something in your vehicle affecting your dongle.
(I'm still thinking something in your vehicle is affecting the dongle and we have to run it down. If your vehicle happens to have some type of electronics package that provides router functionality, you could try using Infrastructure Mode to connect to that, just like you would for a home wifi system.)
I live in a rural area, the only router that shows at home is mine. I never proceeded to connect in infrastructure mode, but did go as far to see that it could see my home network.
It's definitely not the vehicle. I can take the scanner in the house, disable my home wifi, and the scanner will not go into access point mode or generate an IP address. If I turn the home wifi back on, I can then start AP mode on the scanner and it will report an IP address.
Similar thing for in the truck. No wifi signal available in truck, the scanner will not start AP mode. I took my deactivated wifi hotspot out to the truck. I was then able to start AP mode, 1st try, no problem. I tried 20x or more before that, including multiple resets and power sources (thinking it was my truck) it would never work, or report an IP address.
Jeff.
Reading all this, it seems that when the AP mode starts it checks for a free channel or going into share mode on an already active channel, but if it doesn't see any channel it gets stuck in that program code and never leaves it until it sense an active WiFi channel.
Sounds like it goes in a loop trying to negotiate a channel and stays there without timing out and picking one.
Maybe, and I would not be able to test this out where I live, the AP mode is designed to scan the Wifi channels to then pick an empty or open channel. If there are no Wifi channels then possibly the AP mode goes stupid and does not pick a channel??
It would be pretty tricky for me to find an area near where I like that would no NO Wifi signals.
Do "we" know for sure this is how AP mode & the dongle is supposed to work? While I could have missed it when the wifi features came out, I know I haven't seen anything from uniden saying there has to be a wifi network in range to start AP mode. If I missed it in the manuals, maybe someone can point me to where I can find the info.
Based on how I got mine to work, your explanation certainly fits. I'd just like to know if that's how it's supposed to work.
Jeff.
Wrap the dongle in aluminum foil?
I turned off my 2,4GHz net and only had the 5GHz running and when starting AP mode in the 536 it goes 5 sec and then tripple beeps and returns to the menu. After starting the 2.4GHz net it goes 5 sec and then says "Access point mode started".
/Ubbe
Clearly sounds like a firmware or programming problem that NEEDS to be fixed along with the need to be able to CHOOSE the wireless change AND enter a STATIC IP address.
I would guess the programming requests the dongle to scan for active channels. If the dongle does not find any active channels it does not stop the scan and choose a channel, it just keeps scanning for active Wifi channels, kind of site survey loop?? Seems that a time out timer is needed in this case and an instruction for the dongle to default to a channel and/or ASK/PROMPT the user to choose a wifi channel!
UPMan are you listening?
When in access mode it's going to ask you to input an ssid, so make it jeff truck or the default which I believe is BCD536hp something, you press enter, it will then ask what security feature you would like which I always do WPA2 as security and then it asks you to set a password, make it jeff or whatever you want the password to be. Then i believe it's gonna ask you to confirm and press yes, when this happens what the wifi dongle will do is that it's going to send out a wifi connection to a devices
