60 control on 46.22
BFD319
#1
Anyone no whats up with Westchester fire (60 control) comming over 46.22 sounds like a simocast of 46.26. real loud signal down here on L.I. started about mid may
GTR8000
Well Known Member
BEE00
#2
You are hearing Katonah's simulcast of Fire 16 from the trunked system.
BFD319
#3
Thanks, that must be it. now that I tuned into it i don't hear everything going on must be just when they are on the air.
SCANdal
Silent Key
Hudson Valley, NY
#5
com,
Am I correct in presuming that since 46.220 is in carrier squelch when simulcasting TG 1680 that it's a one-way only link (800 TRS to VHF low band)? I'm gathering that it's set up for members with 2 channel pagers who, once paged on 46.260, can switch over and monitor ops while enroute to the firehouse.
SCANdal
GTR8000
Well Known Member
BEE00
#6
SCAN,
I believe that's what it is, so that members enroute to a call can still monitor the post-dispatch transmissions on their pagers.
Ossining, NY
#7
Scan, yes that is the reason. Yorktown Heights FD had switched their responses to Fire 17, but when they found this "problem" they reverted back to 46.26MHz. And actually it is 470/476MHz to low band not 800MHz.
