Likely FT8 between 7074-7076 kHz, JT65 between 7076-7078 kHz
If you see it again, FT8 uses a 15 second cycle. JT65 uses 60 second cycle. Both have a guard interval (silence) at the end of the cycle. JT65 goes quiet starting at 42-45 seconds. FT8 would use something similar like the last 2-3 seconds to be silent.
Software is available as wsjt-x
WSJT Home Page
You must have your computer clock synced within 2-3 seconds of other users or decoding will fail. GPS, NTP, or WWV/B are all adequate.
If it didn't follow the cycle pattern, I'd assume its some other MFSK and would hope I could get it decoded with fldigi
