796D & P25 programming ?
swm239
Hello, trying to program in 2 different P25 trunking systems here is WI. Getting hung up on the correct program setting, I have been using # 5 which is Type 2 P25 VHF. Do not think this is a type 2 system as it does not seem to work showing TG's. I can hear audio fine, just won't track it.
Perhaps the 796D is not able to trunk a standard P25 VHF system? Would appreciate any thoughts on how to proceed.
Thanks,
Scott
davidmc36
South East Ontario
What systems are you trying to do? Are they P25 or Motorola Type two with APCO-25 digital TG's, cause that makes a difference. Totally different system types for your scanner.
swm239
796D & P 25 programming
Hi David, the systems are both P 25 but not type 2.
Thanks for your help.
Scott
datainmotion
Hoi Polloi
Colorado
Wirelessly posted (Clacking rocks together: Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; DROID X2 Build/4.5.1A-DTN-150-30) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Scott,
Here's my dumb question - do you have each system set up separately in the scanner?
Mike
swm239
Hi Mark, actually they are in different radios. I can hear the audio just fine, I am unable to set it up to track and display TG's. Another person thought the 796D was not able to track a straight P25 type of system. Other then option # 5 which is type 2 / P25 / VHF and I am not sure what to select. Looking at the custom options they are both looking for the base / offset / spacing angle as well.
Thanks again, Scott
