SteveC0625
Order of the Golden Dino since 1972
I just received a couple of CDM750's. One came with the standard CDM microphone with the 10 pin RJ style connector (AARMN4025.)
The other came with an 8 pin RJ connector. This mic is the HMN1056 which was used on the Radius/Maxtrac radios.
I am finding conflicting information about using an 8 pin mic in the CDM's. Several sources say the 8 pin Radius/Maxtrac mics work just fine in the CDM's, but then I find this warning over on repeater-builder.com:
NOTE: The CDM series is the current replacement for the Maxtrac / Radius / GM300 line, and at first glance you'd think that a Maxtrac microphone will fit. Yes, it will but you won't like the results and you WILL be sorry. The CDM uses a 10 pin RJ-style mic jack, where the Maxtrac uses an 8-pin. Yes, you can force a 8-pin plug into the jack, but the outer ridges of the plug will mangle the outer two pins of the 10-pin jack. The odds are 9 in 10 that you will end up replacing the 10-pin jack, and it's not an easy fix.
So which is the better advice? I'd really like to use the HMN1056 or, even better, the HMN1035, but don't want to break anything in the process.
Thanks!
Thanks!
