Hey All, I'm working on a project for a dedicated APRS repeater, and I hoping to use an old Mic-less Azden 7000h I have sitting around doing nothing.
I would like to use it with a Mobilinkd TNC2, which means I need to turn the 8-pin into a TRRS connection.
I am a novice at making adapters, and was hoping that someone could help me figure out how I need to connect these pinouts.
AZDEN PCM-463 MICROPHONE.
PIN 1 MIC.
PIN 2 MIC GROUND.
PIN 3 -
PIN 4 DOWN.
PIN 5 UP.
PIN 6 COMMON GROUND (up/down etc).
PIN 7 PTT.
PIN 8 + 13.8 VOLTS.
Mobilinkd TNC2
TRRS – 3.5mm TRRS audio connector for Radio.
1. Tip = Speaker (audio input to TNC)
2. Ring 1 = PTT
3. Ring 2 = Mic
4. Sleeve = GND/Common
I see where PTT, MIC, and Ground would line up, but I'm unclear on how the "Speaker" input source from the 8 pin would be.
Any help would be appreciated.
Thanks.
PIN 1 MIC.
PIN 2 MIC GROUND.
PIN 3 -
PIN 4 DOWN.
PIN 5 UP.
PIN 7 PTT.
PIN 8 + 13.8 VOLTS.
Mobilinkd TNC2
2. Ring 1 = PTT
3. Ring 2 = Mic
Thanks.
