800 mgh
butchhunter
griffin ga
hello all. i have a pro 2018 and it has worked fine up untill the city police and county sheriff dept changed to 800 mgh. now i hear nothing. does anybody make a plain jane 800 mgh scanner that dont cost $300 to$400? all i need is around 10 channels. all the bells and whistles i dont need, i just want to hear the police calls and sheriff calls.
thanks
burner50
The Third Variable
Moderator
NW Iowa
Here's the thing...
Assuming your listed location is correct...
You will need a scanner capable of tracking their trunked system and decoding P25 digital signals...
So a scanner that just receives 800MHz won't quite do it for you.
Just like you were told back in June...
butchhunter
griffin ga
mgh
thanks for the reply BURNER 50, i did not know i would get so many people upset over mgh or mhz or msg or whatever.
thanks again.
chrismol1
Saratoga
To decode the 800 MHz P25 signals you need a scanner equipped with a digital decoder which isn't a cheap piece of hardware at the moment. You're going to need one of those $300-400 if you want to listen.
I know you could probably get a good deal watching auctions on ebay. GRE, Uniden, RadioShack all make digital scanners
burner50
The Third Variable
Moderator
NW Iowa
22 posts deleted...
Seriously, this thread has a specific topic and this site is a place to learn.
I cannot believe the number of posts nitpicking somebody who came here to try to learn something new about the hobby.
You guys should be ashamed.
Sent from my DROID X2 using Tapatalk
