18bravo
What’s are some of the differences between the two radios?
only if you have possession AND custodyOne is a luxury transceiver the other is not.
Just as I suspectedOne comes with a fancy rolex and one gets the timex
Came here to say this. Glad to see I wasn't the only one 😂One is a luxury transceiver the other is not.
Out of curiosity, what is the price differential between the two versions? How much are you paying for hazloc certification?
And are there any actual physical differences between the two models?
A few years ago (Ok...some of you might say MANY years ago...) I examined two identical Sabers, but one was a green dot, full IS (Intrinsically Safe) version, the other, standard. Other than the added decals I found NO other differences, internally or externally.
Now, the battery...I understand that an IS battery has a current limiting feature that does make it different than a standard NiCd battery. (at the time, this was pre-Lithium days)
If there were any such differences in the IS radio, then they may have been lost in a repair done before I got my hands on the radio. But I'd have no way of knowing its prior service history.
I suspected at the time, and still do, that the radios were all built to identical standards and would be safe to use in the same hazardous locations that the IS version is certified for. And that the IS certification basically was nothing more or less than purchasing an insurance policy, while the radio itself was completely unchanged.
I have no information that contradicts my supposition.
"You could have googled that for yourself....."And are there any actual physical differences between the two models?
