Srobo said:
I am looking for an antenna to mount in my attic to monitor an 800mzh system. I have read Yagi's are directional but the system I am listening to has three towers right now and will eventualy have a fourth. What would be a good choice for multiple towers?
Are the towers all on their own separate control channel frequency, or are they sharing the same one? If they're all the same, then you have a simulcast system. We have a few simulcast systems in Michigan, and Uniden scanners in particular have difficulty with them. These simulcast systems are using CQPSK modulation (Compatible Differential Offset Quadrature Phase Shift Keying). The Radio Shack (GRE) PRO-96/PRO-2096 scanners cope with these systems better than the Unidens.
When monitoring a simulcast system with a Uniden, I found using a Yagi antenna directed at only one tower seems to help.
If is is not a simulcast system, than you would be better off with an omni-directional antenna like DickH suggested.
