820.6500???
Robbyboy
Cat Herder
Richlands, NC
Can someone here provide a sanity check? Looking at my Pro-2051, I have the above frequency programmed in and it sounds like I am getting a Motorola Control Channel over it. This frequency is an oddball as this is normally a input frequency as opposed to output. What makes this more interesting is that I cannot find any FCC data... Maybe someone knows something I do not....
brian
DB Administrator
South Carolina
Check 865.6500 - 45Mhz up is the output. But I agree with Larry, it's either an image signal or intermod.
KE4ZNR
KE4ZNR@radioreference.com
How did I miss this thread??? I am getting senile :lol:
Anyway, yep...image/intermod....
