89D special alert preview not playing
code3cowboy
So I went to preview an annoyingly loud alert tone recently and noted no audio from my speakers. It seemed to play and all. All of the volumes were set properly, system sound is enabled, and I have even uninstalled and reinstalled (and repaired) the software. Any ideas?
Muhlenberg County, KY
what OS are you running? I've got KPG-89D installed on 2 computers, one running XP Pro and the other Windows 7. XP has no problems playing the special alert tones, but 7 does. And to no avail have I found a solution to get Windows 7 to play the tones.
