9511 Display
tech2461
Bradenton, Fl
Does anyone know how the alpha descriptors are configured? Line 1 appears to be channel name. Are the lines each custom programmable for descriptors or just one line or ???
12dbsinad
You can set the display to have either one or two lines. If it's set to 2 lines the top line displays the operating Zone and channel number. The second line is your Alpha text. If it's set to 1 line, it's just the Alpha text, enlarged. There is also custom editing of symbols and characters for the Alpha line as well.
Hope this helps.
