996 question
jrs71
Southern Illinois
I currently have 6 systems programmed in my 996 using ARC996 beta. In scan mode, and on one particular conventional system only, the letters 'DSKP' appear each time this system is scanned. This shows up on the top left part of the screen, exactly where 'HOLD' appears in Hold mode. I couldn't find anything regarding this in the owners manual, nor in the ARC996 manual. Anyone know what DSKP is?
Thanks, Randy
jrs71
Southern Illinois
Thanks, I found it upon reviewing the software setup....Awesome scanner but a bit of a learning curve here from the scanners I am used to.
