996 settings question
For status bits, if the TGID you monitor are not evenly divisible by 16, then the system is using status bits.
For a very basic example, let's say you pick up a TGID of 16001, this means simply that TGID 16000 + Status Bit 1 is being used. If this is the case, enable your status bits.
More info here, noticed that status bits 8 to 15 and encrypted (DES)
http://wiki.radioreference.com/index.php/Motorola_Type_II
DonS
Franktown, CO
If it's a "P25 Motorola 800 / 700 MHz digital system", it seems pretty unlikely that it would use any "status bits" (at least, as far as that term relates to the low 4 bits of a talkgroup ID), since those don't exist on P25 systems.
